Re: GTI post service query
I don't see why VW would check these things unless it was part of the 'lube service'
the lube service is a filter and oil change, it also consists of a visual check. as i have found out the visual check enables them to tell you what they think is wrong with the car and hopefully you will pay them to fix it.
Quote:
Originally Posted by
tonyrafferty
Exactly! Maybe they are just scouting for business. I may be worth getting a second opinion tho. See what some of the other forum members say.
i would go for a second opinion mate to be fair, cause stearing and bushes are both looked at in an mot, if the second opinion picks them up then i would go back to the garage you got the car from and show them your evidence, or could go to the VOSA and report the mot test center, cause what goes on a lot of the time is that secondhand car dealer is friends with a test center and sometimes they pass cars that sould not be passed i know of one in hindhead that this happens at all the time.
Hi mate, reading your post I would say that VW are looking for business as the problems listed are suspension related and perishable they can deteriorate as soon as 3 months after an MOT, not to mention the cost quoted......... £700 to carry out the work seems V steep to me for relatively simple work, get a second opinion, it might save you some money.
thanks yoogin and v6dub for your thoughts - this maybe wishful thinking but i guess by getting a second opinion i am hoping they will either say these problems do not exist and to forget about it or that they will say the problems were probably there when i bought the car in which case i can then go back to the original garage with some evidence. i wonder if its possible to get hold of the MOT report from october????
anyway, i am going to another garage tomorrow, i will update this post as and when.
thanks again, Tony
i had my rear bushes changed about two months ago at a cost of £25 quid (i brought them myself from a A1 Motorstores outlet) for both rear bushes, and my local garage charged me £80 quid to fit them,
you could fit them yourself its dead easy to do but its a right pain trying to the bushes out without a press you could try with a hacksaw, hammer and a blow torch as i know of people who have done this but i would still say the bushes would not come out without a fight thought plus its a bit brutal.
the absence of a press was why i took my to my Local garage
as for the track arm if it aint knocking or vibrating the steering wheel i wouldnt worry about it till it does.
hope this helps
