Alarm problems
I bought my 1999 Golf TDi with the front passenger door window/lock etc inoperative. Yesterday I fixed the whole lot by replacing the plastic window clips etc with the metal clips and getting that awkward clip back on behind the key lock. Put it all back together and proud as punch it all worked. A couple of hours later I heard an alarm going off?? Went out and saw the golf having a tantrum. Tried everything to switch it off before pulling the battery lead.
I then went on to your site, had a good search and done the following. I dried as much as I could with a hairdryer (although nothing felt or appeared damp) and checked the no. 14 fuse. All the footwells and tail gate also appeared bone dry. Everything appeared fine.
The only thing of note I saw behind the door card of the passenger door was that the door light connection has no door light to plug in to. I also pulled up the passenger footwell carpet to try to get the CCU but can't find it (the CCU not the carpet).
I eventually just pulled the 14 fuse and everything went silent although now the electric windows don't work. Everything else does. Glad its winter........
Any help would be great
