Vw golf mk6 fuses
Hi all,
I’ve got 2012 golf dsg 1.6tdi, just had a recon MegaTronics unit fitted. Since being at the garage I now have a new fault & mill lamp on. (On return)
P0670 glow plug control.
I’ve just been looking at the fuses & I believe f27 under bonnet should be for the glow plugs.
This is currently where the fuses are located on it’s returned.
I’ve been in contact with local garage & been told they have not had any contact with the fuse side of things.
Does anybody have a wiring diagram? Or can check fuse location
ℹ currently have 50amp fuses in location f28 & f30
Many thanks
Lee
Re: Vw golf mk6 fuses
Mechatronics. Yes it is fuse 27 and to change the mechatronic they would have no need to access the glow plug controller, likely a coincidence... it happens.
