Front and back brake disc&pads change Q5
Hi - I had MOT few days back and it passed. Audi dealer advised to change front and back disc/pads urgently and quoted 1800£. There is no lights on dashboard. He says 90% worn verbally. Any local independent audi specalist recommendations in Welwyn/Hatfield. I am not sure which parts to order as there are many choices .
VIN - WAUZZZFYOL2044259
Thanks in advance
Re: Front and back brake disc&pads change Q5
If you find someone to do the work I suggest you let them supply the parts, trying to get a garage to fit your own parts is a quick way to **** them off.
The VIN is WAUZZZFY0L2044259
Front disc 8W0 615 301 AB
Front pads 80A 698 151 F
Front pad (left) contact 80A 615 121 A
Rear discs 8W0 615 601 E
Rear pads 8W0 698 451 BG
Rear (right) contact 80A 615 121
I f the suggested replacement is due to wear, the warning light would need to be on so I can’t see 90% being accurate and if that worn, the MOT tester should have picked up on it.
