1 Attachment(s)
ACC & Audi braking guard not available
I was wondering if one of you could help with an ACC fault that has started to appear very regular.
I have attached the VCDS faults. (Member from a Audi A6 group scanned for me last night)
am I correct in thinking its the shark fin antenna that could be the cause of the issue?
Thanks in advance
Jaybee
Code:
Wednesday,05,February,2025,17:13:34:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64)
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUZZZ4G8EN086271
License Plate: JP06BAN
Mileage: 196485km-122090mi Repair Order:
Address 01: Engine (J623-CGQB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 589 G HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0003
Revision: 57H25--- CVN: 07C313D2
Coding: 322A403225660B020000
Shop #: WSC 09063 006 1048576
ASAM Dataset: EV_ECM30BTD0114G0907589G 001003
ROD: EV_ECM30BTD0114G0907589G.rod
VCID: 387F9DE783538256BB-806C
VINID: 9D196AAAA1172157802060870403612CC1
1 Fault Found:
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000 Dataset Number: 4G0909863C 0036
Coding: 7E04010202
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285F4DA753F312D62B-807C
1 Fault Found:
145408 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 125
Mileage: 196003 km
Date: 2025.01.30
Time: 05:37:05
Control Module temperature: 9 C
Voltage terminal 15: 14.122 V
Velocity_vehicle_reference: 13.39 m/s
Longitudinal_acceleration_vehicle_reference: 0.21 m/s
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 J
Component: H-BNT-EU H53 1034
Revision: -------- Serial number: 190K/0D7560723
Coding: 080101050003FDEF7FB0CF1E00000003080001000200000000
VCID: 3169A0C36829531EFC-8064
Subsystem 1 - Part No: 8R0 060 884 HF
Component: EUR 2020/2021 3101
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD002YDB2
Subsystem 3 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MK30001Z
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
5 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 194907 km
Time Indication: 0
Date: 2024.12.20
Time: 17:45:19
Freeze Frame:
Text: DUA009,,D,0,0,6
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 196485 km
Time Indication: 0
Date: 2025.02.05
Time: 16:50:41
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000010
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 162
Reset counter: 125
Mileage: 193202 km
Time Indication: 0
Date: 2024.11.19
Time: 05:22:55
Freeze Frame:
Voltage: 14.40 V
01524 - Antenna for Telephone
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 7
Fault Frequency: 1
Reset counter: 252
Mileage: 193114 km
Time Indication: 0
Date: 2024.11.17
Time: 15:06:08
Freeze Frame:
Voltage: 14.40 V
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 193114 km
Time Indication: 0
Date: 2024.11.17
Time: 15:05:58
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2643439F59E704A619-8072
1 Fault Found:
U1113 00 [00001001] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 85
Mileage: 196004 km
Date: 2025.01.30
Time: 05:38:11
Control Module temperature: 11 C
Voltage terminal 15: 14.585 V
Velocity_vehicle_reference: 3.63 m/s
Longitudinal_acceleration_vehicle_reference: -1.19 m/s
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000120711137 Dataset Number: 4G8909548A 0013
Coding: 04C23B191111
Shop #: WSC 59568 004 1048576
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0118 - Function Restriction due to Faults in Other Modules
Freeze Frame:
Fault Priority: 6
Reset counter: 85
Mileage: 196003 km
Date: 2025.01.30
Time: 05:36:48
Outside temperature: 2.0 C
Voltage terminal 15: 14.5 V
Control Module temperature: 14.0 C
End-------------------------(Elapsed Time: 07:56)--------------------------
Re: ACC & Audi braking guard not available
Where is the rest of the scan? That needs to go on ODIS to have its coding and software sorted.
The full scan was too big to upload so I deleted the none faults. I can try paste the full scan.
Code:
Ross-Tech: Home
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 20 28 34 36 3B
3C 42 44 46 47 52 53 55 56 5F 62 6C 6D 72 82 85 88 89 8B 8E
8F 90 A9 C0
VIN: WAUZZZ4G8EN086271 Mileage: 196485km-122090miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
1 Fault Found:
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 997 749 A HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1001
Revision: --H16--- CVN: BB008EF0
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 397998E3B8599B5E44-806C
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 49AFDD0592F5BBA0CB00
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3B7582EBB265A94E56-806E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DP HW: 4H0 907 064 DP
Component: BCM2 2.0 H35 0510
Revision: 00002001
Coding: 05B92F46000000000000
VCID: 7AFB47EFF5DF50460D-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 0213000333532009
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 108
Mileage: 195666 km
Time Indication: 0
Date: 2025.01.25
Time: 09:30:07
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0154
Revision: AA000000 Serial number: 00000079483349
Coding: C038320085006201000001010101112030303333283333
VCID: 3A7B87EFB55F90464D-806E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AN HW: 4G0 820 043 AN
Component: KLIMA 4 ZONEN H14 0093
Serial number: 06111300041691
Coding: 36A200BE35
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6BD572AB8285F9CE86-803E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001494622
Coding: 0907201109749FF29F8100C4A0001800CF9D47082F080301800108546F00
Shop #: WSC 13737 004 1048576
VCID: 6FED66BBBE9D05EEAA-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 131019 H36 0080
Serial number: 131028100506
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21937695
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
Component: E1 - LDS H07 0044
Serial number: 05 11 2013 00001035
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000008111300010024
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000029101300010107
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106971000004936207
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 402987D6000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 010000
VCID: 23455A8B22D5F18E7E-8076
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 211
Reset counter: 85
Mileage: 193114 km
Time Indication: 0
Date: 2024.11.17
Time: 15:06:13
Freeze Frame:
Text: 00000000
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 AB HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0060
Revision: -------- Serial number: 56261331103924
Coding: B83B20
ASAM Dataset: EV_EPHVA2CAU57X0000 002012
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 72EB6FCFA5AF280645-8026
Coding: 7E04010202
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 125
Mileage: 196003 km
Date: 2025.01.30
Time: 05:37:05
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00FP0KC Dataset Number: 4G0909602H 0002
Coding: 3032343631334E303539554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 366393DF89477426A9-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405122V2069IQ
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB406922V20D9D
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB401050PGEQHT-
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB401250OM6F0T8
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405F2E15C70BX
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB406528LHUHHTS
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MK5001CF
Coding: 0004FD
VCID: 387F9DE78B538256BB-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 11 08 2013 D0289955
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G9 920 950 P HW: 4G9 920 950 P
Component: TDieGb AccNv H58 0621
Revision: 29131233 Serial number: 658181013596019
Coding: 238F20083F552600010600
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3D718CF3AC71A77E68-8068
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001168601 Dataset Number: 4G0909515H 0067
Coding: 00CD077D00
GVL: FFEFED4CFEE368CD7000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 9120941603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130911000000000001D5
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 0F0100
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CF741F7FFEB6E761F-8028
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 N HW: 4G0 919 158 N
Component: KLIMA FOND H08 0093
Serial number: 07111300041329
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3A7B87EFBD5F90464D-806E
1 Fault Found:
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [00001001] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 85
Mileage: 196406 km
Date: 2025.02.04
Time: 16:49:21
Voltage terminal 30: 14.67 V
Outside temperature: 11.0 C
Right Rear Upper Body Vent Motor-Act.val.: 12018
Right Rear Upper Body Vent Motor-Target value: 12018
Right Rear Upper Body Vent Motor-Stop open: 11417
Right Rear Upper Body Vent Motor-Stop closed: 10000
Right Rear Upper Body Vent Motor-Last active operating mode: 5
Right Rear Upper Body Vent Motor-Active operating mode before last: 6
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Dataset Number: 4G0909553F 0034
Coding: 008006
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_003_AU64.rod
VCID: 2E53BBBF71174CE6E1-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0154
Revision: AA000000 Serial number: 00000079483348
Coding: C0383B0085016201000001010101112030303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00RGV3 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377D9EDB8E4D8D2EB2-8062
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 E HW: 4G0 907 566
Component: J769 SWA MasterH04 0040
Revision: 00H04000 Serial number: 6PZ 010 287-04
Coding: 0001104
VCID: 3169A0C3A829531EFC-8064
Subsystem 1 - Part No: 4G0 907 568 E
Component: J770 SWA Slave H04 0040
Subsystem 2 - Serial number: 6PZ 010 287-24
Subsystem 3 - Serial number: 5F24.10.1300H04000AMS14660
Subsystem 4 - Serial number: S14660
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F1E005E01628202080013
VCID: 4581E413CCA1EFBE30-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0006018809 Dataset Number: 4G0909852H 0027
Coding: 011101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BAFCF652F680685-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0318808168
Coding: 013B0E22A0B93081832009840C010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00005169382
Coding: 010000
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000050983
Coding: 030000
VCID: 1D316C7304B1C77E48-8048
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F1E005E01628202080002
VCID: 4487F917C79BD6B627-8010
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 28
Mileage: 193928 km
Time Indication: 0
Date: 2024.11.30
Time: 08:28:05
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000873780 Dataset Number: 4G0909522D 0007
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C57B1B7470B3EF6CF-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 131112-0002-170
Coding: 11226F601000B300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D51BCB37C1137FED8-8078
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109KZ0DB006602
Coding: 010103010000000001
VCID: 2D51BCB3741137FED8-8078
5 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 194907 km
Time Indication: 0
Date: 2024.12.20
Time: 17:45:19
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 196485 km
Time Indication: 0
Date: 2025.02.05
Time: 16:50:41
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Reset counter: 125
Mileage: 193202 km
Time Indication: 0
Date: 2024.11.19
Time: 05:22:55
Freeze Frame:
Voltage: 14.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 252
Mileage: 193114 km
Time Indication: 0
Date: 2024.11.17
Time: 15:06:08
Freeze Frame:
Voltage: 14.40 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 193114 km
Time Indication: 0
Date: 2024.11.17
Time: 15:05:58
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 010F1C004001628202080002
VCID: 479DEE1BF6ADFDAEC2-8012
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0118813
Coding: 0204000101000000000102000000
Shop #: WSC 36194 005 1048576
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 299300054 Dataset Number: 4G0909541D 0027
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 356194D394417F3EA0-8060
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 L HW: 4G0 919 604 L
Component: HeadUpDisplay 004 0201
Revision: 00000000 Serial number: 00000000000000
Coding: C70000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7_AU57.rod
VCID: 3467A9D79F3B663697-8060
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G0909547C 0030
Coding: EA060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4G8 881 073 HW: 4G8 881 073
Component: P2G H02 0032
Serial number: 0DAM6FM Dataset Number: 4G0909880D 0018
Coding: 672FF0
ASAM Dataset: EV_P2GDriveSideFrnt 001006
ROD: EV_P2GDriveSideFrnt.rod
VCID: 6ED37BBFB1970CE6A1-803A
Valve block 1 in front seat driver side:
Subsystem 1 - Part No SW: 4G8 907 181 HW: 4G8 907 181
Component: PSLB H02 0023
Serial number: 00000000000000D9J1QS
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 0DAM6FW Dataset Number: 4G0909881D 0017
Coding: 272FF0
ASAM Dataset: EV_P2GPasseSideFrnt 001006
ROD: EV_P2GPasseSideFrnt.rod
Valve block 1 in front seat passenger side:
Serial number: 00000000000000D9J55X
Coding: 7E04010202
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 85
Mileage: 196004 km
Date: 2025.01.30
Time: 05:38:11
ROD: EV_BC7.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 85
Mileage: 196003 km
Date: 2025.01.30
Time: 05:36:48
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 0066E608031F0376070308004240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169A0C36029531EFC-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 131028200600
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 2B55B2AB420539CEC6-807E
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0007
Serial number: 131025201482
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS_VW12.rod
VCID: 244759972FDBF6B607-8070
Your out of data VCDS interface is partially letting you down here but I really get annoyed by this faults in other models error, like WHICH models FFS! Reading through the full scan, the only faults that attract my attention are the software and security errors in address 5F which look like a used controller has been installed. The only way I known of dealing with those errors is by using the dealer system ODIS.
Quote:
I will get the software checked when the car is in for service in a few weeks.
I did take the back part of the roof lining apart to access the fin arial, I was trying to see the part number to confirm as a few available. I struggled to get the wires out as very little room and I have shovels as hands. After realising I couldn't take it out I put all back together. The ACC errors seem to have been cured. I'm guessing it was a bad connection in one of the cable I was struggling to unclip. Hopefully this has cured the problem.
