Unlocking when battery flat
Hi, can anybody help.
My friend is stuck in a car park in portugal, he left his lights on and flattened the battery. Now it won't even open manualy with the Key.
Does anybody know the answer? I would like to know for future reference also!
He's in a hire car and thought he'd call me as his Portuguese is not so good!!
Thanks.
:confused:
Re: Unlocking when battery flat
Pull the plastic key out of the end of the ignition. Then remove the cover from the rear end of the door handle, it pops off if you gently pull it. Underneath there is a normal keyhole, insert the plastic key and turn.
Yep, tried that no joy! Electrics need to be fully functional for that to work, thats why its such a mystery!
I think you need to open from passenger door. Well it was like that in my situation after I have installed audio amp wrong. Home that helps.
Lucas
