Hello all,
At the moment double-pressing the key fob all doors including tailgate are opened. I wonder is there a way to change byte coding in VCDS configuration to open all doors except tailgate when the key fob is double-pressed?
Printable View
Hello all,
The tailgate lock is operated by the Body Control Module.
OK. And what difference does it make? For example Carista android app (doesn't support Polo 9N3) has option to enable/disable "Unlock trunk when doors are unlocked". I guess this could be done via VCDS just need to know which byte to change manually...
