VW Caddy 2010 1.6 tdi - no crank no start no glow plug light
Hi all, sorry first post to the Forum, after some advice with a 2010 caddy 1.6tdi suffering no crank no start symptoms. the glow plug light is not visable when the ignition is on and if trying normally the van will not start or crank at all.
traced some of the symptons of this issue out to be around relay 100 in teh engine bay fuse board. but beleive this is presenting as a silution but instead should help me pointt o teh sympton but im a little lost now.
should the supply to this relay be readable across the relevant terminals for the relay supply? if i link out the load side of the relay the fuel pump whirls into action and the van will at least crank however with no start and stil no glow plug lights.
would anybody have any sensible alternative sugestions to help diagnose this issue please?
if testing with vcds i get communciation faults but i think these are all due to a no supply issue>
Have run through with VCDS and get the messaging below
Code:
Monday,01,April,2024,15:23:57:34771
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
Ross-Tech: Home
VIN: WV1ZZZ2KZBX219762 License Plate:
Mileage: 84870km-52735mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZBX219762 Mileage: 84870km-52735miles
01-Engine -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 433C400D09230303C21202EA901BC081300000
Shop #: WSC 35110 377 08192
VCID: 75B7F178B5C94B920C5-8020
2 Faults Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 198
Mileage: 84787 km
Time Indication: 0
Date: 2018.08.23
Time: 00:00:50
Freeze Frame:
Count: 0
Count: 2
Count: 12800
Count: 129
Count: 52224
Count: 0
Count: 0
Count: 0
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 84876 km
Time Indication: 0
Date: 2018.08.23
Time: 00:04:41
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8194
Count: 52737
Count: 0
Count: 65280
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 2K5 937 085 HW: 2K5 937 085
Component: BCM PQ35 B+ 011 1044
Revision: BB011001
Coding: 401A583A8025186A088000829000006443017288524F0160648000000040
VCID: 72BDCA64C4A75CAA297-8026
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 22091 26 0512
Coding: 009795
No fault code found.
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL001MPSV Dataset Number: 2KC003v____ 0221
Coding: 000000000000000000000000000000003055
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 35373178F5C90B92CC5-8060
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AR HW: 5K0 953 549 C
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JIT000AD Dataset Number: 5K0953507AR D005
Coding: 1080060000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 005990ACFA8B7E3A2F3-8054
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K0 920 965 A HW: 2K0 920 965 A
Component: KOMBI H04 0404
Serial number: 00000000000000
Coding: 480000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2D0719181D994352B45-8078
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät für Motor: keine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 163
Mileage: 84877 km
Date: 2024.04.01
Time: 00:22:12
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 230910F1001322
Coding: E9801F0200020200007401
VCID: 6D87D918D1998352F45-8038
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 84877 km
Time Indication: 0
Date: 2018.08.23
Time: 00:22:14
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0404
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD204ECF7946A917-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48C9488C9EBB867AA73-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 140 3001
Revision: 00H17000
VCID: 313F05680D2127B290D-8064
2 Faults Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 84877 km
Time Indication: 0
Date: 2018.08.23
Time: 00:22:12
Freeze Frame:
Battery Volts: 11.5 V
DU
Temperature: 20.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 84877 km
Time Indication: 0
Date: 2018.08.23
Time: 00:22:12
Freeze Frame:
Voltage: 11.50 V
DU
Temperature: 20.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47CB4BB093A58902AE9-8012
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 156 HW: 5K0 035 156
Component: Radio H30 0072
Revision: R0000000 Serial number: VWZAZ1K0646962
Coding: 0500020001
VCID: 6491BC3C0E53C21AABB-8030
End----(Elapsed Time: 00:47, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Re: VW Caddy 2010 1.6 tdi - no crank no start no glow plug light
There is no power to the engine ECU and someone has had a battery charger on it running at too high a voltage but the power to the ECU failed first so it probably isn’t over voltage damaged. It is possibly the ECU relay number 100 (part number 1K0 906 381) and I would use a relay tester to see if it works then bridge out the terminals corresponding to the relay pins 30 and 87 to see if the engine ran. The relay receives a command from the body control module (from memory it is an earth command permanent live) which itself receives a digital command from the steering column electrics in response to the ignition switch position.
engine code or reg no would be more than helpful to help you
Quote:
Originally Posted by
mickeybo
VIN WV1ZZZ2KZBX219762 engine code CAYD.
