2 Attachment(s)
Corrupt MMI code help needed
Hi all
I bought firmware from Audi Q3 Bundle packs updates for Rest of World - UpgradeMyAudi.net
I installed , and worked fine, but when I tried to install the map updates that came with it, I could not select anything on that sd card, after numerous tries, I read to just re install the firmware again, and try again, which I did. I think I accidently rebooted the MMI when it completed, rather than scroll all the way down to the bottom and select it to finish the setup.
Now the MMI "display" coding is broken, as it does not display the icons like it should and I can not see the wording in the corners and also the prompts and some menu items etc
Attachment 39396
Attachment 39397
