MMI Problems
RS4 2018 build date.
My MMI would randomly reboot itself with anything from several days to 2 or 3 minutes between reboots.
It has now reached a point that it practically continues to reboot itself all the time.
The current version is MHI2Q_ER__AUG22_P5092, MU Software 1329
If I do a VCDS Applications, Optical Bus Diagnostic. I get a fail or this test may not be supported responce.
I think I have a CAN Gateway fault and have a second hand module on its way but I'm gathering as many pearls of wisdom I can get before it arrives.
For example am I getting the correct responce from the Optical Bus test? Is it faulty or is that test not actually supported on my car.
Many thanks in advance.
A VCDS scan report highlights below:
Code:
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W7 907 468 F HW: 8W7 907 468 E
Component: Gateway H42 0123
Revision: 7C000001 Serial number: 0187C823318414 Dataset Number: 8W0909515J 0059
Coding: 03010001000086405407000000590012E8980007900000000175078E10000000
Shop #: WSC 06335 790 00001
GVL: 01583C580800020040DC08000002C800110C0000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4EC66454705BBB3ACD7-801A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180411121146 20913
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 6664487304
3 Faults Found:
2563 - Cellular Antenna
B1053 13 [008] - Open Circuit
[GSM/UMTS_Breakdown]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 5
Reset counter: 134
Mileage: 121925 km
Date: 2023.09.24
Time: 09:14:43
Voltage terminal 30: 12.40 V
131723 - Body Control Module (Central Electric 2)
U0141 00 [008] - No Communications
[Timeout_Node_0x8B_DiagAdress_46_BCM2]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 131
Mileage: 126636 km
Date: 2023.10.05
Time: 09:05:05
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 128
Mileage: 121643 km
Date: 2023.09.16
Time: 13:00:40
Total static current-current total quiescent current: 95 mA
Total static current-Total time quiescent current exceeded: 1.0 H
EM_vehicle_state: 00 00
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
Dataset Number: 8W0909519B 0010
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 79ACE7889955CC82485-802C
1 Fault Found:
0768 - Local Databus
U1030 00 [008] - Electrical Malfunction
[lin data bus defect]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 124
Mileage: 124485 km
Date: 2023.09.29
Time: 11:18:58
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Dataset Number: 8W0909501J 0052
Coding: 013500002FB100406309A0006E00080233004010804306502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 015C8F68F1859442005-8054
Anti-theft alarm system sensor:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY180743EV2
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000099646613
Rear lid opener control module:
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12005980
1 Fault Found:
65896 - Databus
U1121 00 [008] - Missing Message
[Climatronic control module: Klima_03: no signal/communication]
Freeze Frame:
Fault Priority: 6
Reset counter: 142
Mileage: 120978 km
Date: 2023.09.13
Time: 14:40:31
Supply voltages-Terminal 30 power supply: 13.071 V
Supply voltages-Supply voltage Terminal 30 - 2: 13.071 V
Supply voltages-Supply voltage Terminal 30 - 3: 13.044 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 �C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 �C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 C HW: 8W5 035 035
Component: MU-P-LND-EU 034 1329
Serial number: A829D0JB065237 Dataset Number: 8W0909545VM 0004
Coding: 019462010000000053111102000A00332F000BE701700100DE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 372821B0EFC11AF2FE1-8062
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8W8 919 605 HW: 8W8 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00114111700820328
Multimedia system control head:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK121031800040304
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
3 Faults Found:
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 120976 km
Date: 2023.09.13
Time: 14:34:43
Voltage terminal 30: 14.8 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in sound]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 131
Mileage: 126247 km
Date: 2023.10.04
Time: 12:55:12
Voltage terminal 30: 12.5 V
Temperature of MOST transceiver-max.value: -50 �C
Temperature of MOST transceiver-min.value: -11 �C
Temperature of MOST transceiver-Up-to-date: 48 �C
6672 - Optical Data Bus for Display in Instruments
U10CF 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in instrument cluster display]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 142
Mileage: 123619 km
Date: 2023.09.26
Time: 17:25:20
Voltage terminal 30: 14.0 V
Temperature of MOST transceiver-Up-to-date: 47 �C
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 30000000017278 Dataset Number: 8WA909850A 0002
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736.rod
VCID: 2F3819D01791D232A61-807A
1 Fault Found:
8390147 - Tire Pressure Monitoring
C10DC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 121814 km
Date: 2023.09.19
Time: 14:30:25
Expanded ambient data 1-Left front tire pressure sensor: identification: 560360898
Expanded ambient data 1-Right front tire pressure sensor: identification: 560350137
Expanded ambient data 1-Left rear tire pressure sensor: identification: 560360910
Expanded ambient data 1-Right rear tire pressure sensor: identification: 557570184
