2012 ibiza pulling to the left
A friend has been looking at a 2012 ibiza that has an issue with pulling to the left badly. He has checked the brakes and no problems with them. He mentioned that with the calipers removed it seemed really stiff to turn the left drive shaft but with no obvious reason for this. It has had 2 arms fitted but over 12 months ago and only just started pulling. This seems to be a common problem when you Google it but no one has a real solution. The only one suggestion is that the subframe needs adjusting to correct bad camber. Does anyone know of what might cause this?
Cheers Mike
Re: 2012 ibiza pulling to the left
If it is more difficult to turn the left shaft than the right I would investigate the back of the wheel bearing and CV for rust.
