Skoda fabia vrs 1.9 tdi 2005
Hi I have a Skoda vrs 1.9 tdi pd
The cooling fans are not kicking in
I have changed the fan sensor on the side of the radiator
I have also changed the temp sensor in the thermostat housing
The fans are still not working
I have also checked all fuses
Any help or direction is a bonus
Re: Skoda fabia vrs 1.9 tdi 2005
Do the fans run if you turn on the air con?
Hi crasher thank you for your quick response
No the fans are not working with the ac on
Check the fan controller under the right wing for corroded wiringhttps://hosting.photobucket.com/albu...ps95ef4cf1.jpg
