Error codes P0263 P0269 P0272 P0266
I have error codes P0263, P0269, P0272 and P0266.
I can’t believe all 4 injectors are bad. Had the dpf cleaned and turbo actuator changed.
Could it be a problem with the high pressure fuel pump?
Many thanks
Rob
Re: Error codes P0263 P0269 P0272 P0266
Which engine code? Do you have a proper VCDS scan you can post?
Quote:
It’s not actually my car. It’s a mates car. I use obdeleven. I will get the scan. It’s weird. All 4 codes at once. I’d get it if it was just one or two.
