2008 A6 C6 Avant 3.0 Tdi. Sudden loss of power. Help with codes please
I have owned this car for 6+ years and have had no significant problems with it. Was beginning to think that it could not last forever and sure enough on a trip back from London this weekend the car suddenly lost power and emitted a fair bit of smoke on acceleration. I assume that it is limp mode. I made it back to Norfolk very sluggishly and there were no further symptoms during the journey. The glowplug warning light was flashing all the way.
Yesterday I plugged in and read the codes. The log is posted below. I realise that I am probably going to end up at a garage but I would like to get an idea of possible problems before I do that so if anyone can help I would be grateful. Also any suggestions for any simple checks I can do.
The 4 relevant codes are in the engine block and I notice that the P0101 occurred about 20 mins before the other 3. (The 3 fan codes are irrelevant - they have been there for years). I assume that the Auto Trans code is set by the ecu because of the engine problems.
After saving these codes I cleared them and went for a short drive. The flashing glowplug was gone to start with but the power was severely limited right from the start. Virtually no acceleration. After 5 mins or so the flashing glow plug returned.
I rechecked the codes again at this point and the only one that had returned in the short drive was the P0235 (Also the Auto trans code).
Code:
Monday,22,June,2020,14:13:47:61099
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
Ross-Tech: Home
VIN: WAUZZZ4F38N166*** License Plate: SN08 ***
Mileage: 322800km-200578mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
55 56 57 61 62 6C 72 76 77
VIN: WAUZZZ4F38N166220 Mileage: 322800km-200578miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02145 785 00200
VCID: 62CB162CBDA11A967D-8036
7 Faults Found:
001683 - Fan 2 Control Circuit
P0693 - 001 - Short to GND - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 314919 km
Time Indication: 0
Date: 2019.08.14
Time: 15:42:41
Freeze Frame:
RPM: 756 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 32.4 %
Voltage: 13.45 V
Duty Cycle: 24.1 %
Duty Cycle: 32.4 %
006473 - Control Module 2 for Coolant Fan
P1949 - 001 - Defective - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 314919 km
Time Indication: 0
Date: 2019.08.14
Time: 15:43:54
Freeze Frame:
RPM: 756 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 24.1 %
Duty Cycle: 32.4 %
Duty Cycle: 24.1 %
Duty Cycle: 0.4 %
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Reset counter: 255
Mileage: 314929 km
Time Indication: 0
Date: 2019.08.15
Time: 09:07:04
Freeze Frame:
RPM: 756 /min
Torque: 101.4 Nm
Speed: 0.0 km/h
Duty Cycle: 16.2 %
Duty Cycle: 18.9 %
Duty Cycle: 16.2 %
Duty Cycle: 0.4 %
000257 - Mass Air Flow Sensor (G70)
P0101 - 001 - Implausible Signal
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 322613 km
Time Indication: 0
Date: 2020.06.21
Time: 16:21:18
Freeze Frame:
RPM: 1890 /min
Torque: 0.0 Nm
Speed: 63.8 km/h
Duty Cycle: 50.1 %
Voltage: 13.15 V
Absolute Pres.: 1060.8 mbar
(no units): 0.0
000305 - Oxygen (Lambda) Sensor B1 S1
P0131 - 001 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 322648 km
Time Indication: 0
Date: 2020.06.21
Time: 16:46:09
Freeze Frame:
RPM: 1470 /min
Torque: 304.2 Nm
Speed: 80.6 km/h
Duty Cycle: 45.8 %
Mass Air / Rev.: 517.0 mg/str
(no units): 0.60
(no units): 0.0
000565 - Boost Pressure
P0235 - 001 - Regulation Range not Reached - MIL ON
Freeze Frame:
Fault Status: 11110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 322651 km
Time Indication: 0
Date: 2020.06.21
Time: 16:49:10
Freeze Frame:
RPM: 1701 /min
Torque: 312.0 Nm
Speed: 75.0 km/h
Absolute Pres.: 2091.0 mbar
Absolute Pres.: 1193.4 mbar
(no units): 0.0
Temperature: 27.0°C
004472 - Linear O2 Sensor; Pump Current
P1178 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 322651 km
Time Indication: 0
Date: 2020.06.21
Time: 16:49:39
Freeze Frame:
RPM: 1953 /min
Torque: 214.5 Nm
Speed: 87.4 km/h
Duty Cycle: 46.8 %
Mass Air / Rev.: 599.3 mg/str
(no units): 0.90
(no units): 8.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 T HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H04--- Serial number: 4466121
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 36639A7C41A9D636E1-8062
1 Fault Found:
005913 - Functionality limited due to Engine Control Module
P1719 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 322651 km
Time Indication: 0
Date: 2020.06.21
Time: 16:49:12
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
VCID: 66C30A3C518966B691-8032
No fault code found.
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0090
Revision: 00H05000 Serial number: 10602401123213
Coding: 0000151
Shop #: WSC 02323 785 00200
VCID: 25414D30EC0FADAE58-8070
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H02 0020
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351F-087565855
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 2B55BB088AEB9BDE8E-807E
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001112453
Subsystem 3 - Serial number: 0126.06.080000000100010304ÿ
Subsystem 4 - Serial number: 010304ÿ
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 322272 km
Time Indication: 0
Date: 2020.06.13
Time: 14:02:54
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030365442
Coding: 0001302
VCID: 1C3768D4DF456C66F7-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0003121
VCID: 3169A960A8C7F10EB4-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8484918
Shop #: WSC 00000 000 00000
VCID: 1A3B6ECCD5711256E5-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0YUUGP
Coding: 0013381
VCID: 29594100801789CE7C-807C
Subsystem 1 - Serial number: 6332CSME3756120D+
Subsystem 2 - Serial number: 6342CSME3756185A7
Subsystem 3 - Serial number: 6352QSME77660A09M
Subsystem 4 - Serial number: 6362QSME7E491B33U
Subsystem 5 - Serial number: 63734SME732776493
Subsystem 6 - Serial number: 63834SME744477710
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026081630371
Coding: 0102142
VCID: 275D47389603BFBE6A-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 72W34EU68
Coding: 3137458
Shop #: WSC 00879 210 88126
VCID: 23455328E23B539E36-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0862900E8
Coding: F5D1DE7730360600
VCID: 2D51B510B4FF95EE90-8078
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091146
VCID: 61C91920B8A7018E64-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364F-087800976
Shop #: WSC 00759 210 91870
VCID: 3B758B487A8B0B5E1E-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: 7ˆt
Coding: 0020122
Shop #: WSC 02327 785 00200
VCID: 2C57B8148FE59CE687-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01126889290000
Coding: 0131835
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 030001
Shop #: WSC 02399 823 56573
VCID: 285F44045B1DB0C663-807C
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 178
Mileage: 322249 km
Time Indication: 0
Date: 2020.06.06
Time: 12:58:00
Freeze Frame:
Voltage: 11.90 V
Temperature: 17.0°C
Bin. Bits: 00000011
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000563041
Coding: 0001103
VCID: 5EB322DC89D93E7659-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: ‡w
Coding: 0020122
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
VCID: 204F5C24F32D48862B-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 69D90100409749CEBC-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394F4087913979
Coding: 0000001
VCID: 2E53B21CB9F9EEF6A9-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801649101
Coding: 0000303
VCID: 24475034E73554A64F-8070
1 Fault Found:
02283 - Video Connection to Output [End Unit]
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 170
Mileage: 321957 km
Time Indication: 0
Date: 2020.05.28
Time: 10:41:27
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000115794
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2806300791
Coding: 344630393135313035442056413032383036333030373931
Shop #: WSC 00000 384 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 320481 km
Time Indication: 0
Date: 2020.02.13
Time: 11:12:35
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 320481 km
Time Indication: 0
Date: 2020.02.13
Time: 11:16:03
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 322272 km
Time Indication: 0
Date: 2020.06.11
Time: 12:02:07
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 322272 km
Time Indication: 0
Date: 2020.06.11
Time: 12:02:17
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 322272 km
Time Indication: 0
Date: 2020.06.11
Time: 12:02:27
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0019458
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8630AV
Coding: 1020105
VCID: 1E3362DCC9597E7619-804A
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0019458
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06340817900538
Coding: 0221116
Shop #: WSC 131071 1023 2097151
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 183
Mileage: 321828 km
Time Indication: 0
Date: 2020.05.09
Time: 18:12:30
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 L HW: 4E0 862 335
Component: Handyvorb2 H20 1120
Revision: 00000000 Serial number: 00000005186185
Coding: 0010920
End-------------------------(Elapsed Time: 02:46)--------------------------
Re: 2008 A6 C6 Avant 3.0 Tdi. Sudden loss of power. Help with codes please
Did you get the the bottom of this problem?
I've just had the same issue with my A6 3.0 TDI 134000 miles today.
Glow plug light started flashing and loss of power- managed to limp home with loss of acceleration
VCDS shows code:
P1719 - 002 -
I've had P0401 Insufficient flow codes flashing up intermittently over the las t2 years regarding the EGR system but can clear these codes.
I wonder if an EGR delete would solve all these issues- I realise there is a £1000 fine if this is picked up at MOT but to replace the EGR system is over £1500!
Maybe I am looking in the wrong place but I would appreciate your experience- otherwise I may have to consider replacing the car; it's worth nothing but I still enjoy it!
Thank you in advance
Yes I did. I'm not expert enough to diagnose your problem but the outward symptoms certainly seem similar.
I took the car to a very well respected independent diagnostics and tuning expert in Norfolk. He tested it and quickly diagnosed a stuck EGR valve. He gave me the option of blanking off the EGR with a plate and reprogramming the ECU to take account for this. The total cost was about £450 and the car worked perfectly afterwards with no discernible difference in performance.
He did say though that it was possible in this case because my car was one of the last of the model without a DPF fitted. He would not have done it with a DPF because it would cause DPF clogging problems down the line. He also said that the emissions reduction produced by an EGR was very minamal and that it would not cause a problem in an MOT. The car would also not show any codes because of the ECU re-programming. I did have it MOT'd elsewhere a few months later and it passed without comment. Was still working fine at 205000 miles when I sold it earlier this year.
