Battery problems
Am using latest HEX-V2 cable to connect to my recently bought A4 B9 2016. Newly registered VCDS aswell. All up and running. The dealer where I bought the car put a new battery in on the morning i picked up the car. DIS shows "Start Stop Malfunction, go to workshop...."
Scan on VCDS reveals 2 faults:
2 Faults Found:
197149 - Generator
U1052 00 [009] - No Communication
[Break_Down_LIN_Communication_Alternator]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 159
Mileage: 114425 km
Date: 2019.12.04
Time: 21:45:15
197175 - Control unit for battery monitoring
U1050 00 [009] - No Communication
[Break_Down_LIN_Communication_Battery_Monitoring]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 159
Mileage: 114425 km
Date: 2019.12.04
Time: 21:45:15
I cant find a BEM code anywhere. I want to try and code the battery because there is a start/stop malfunction error on the dash, bit no fault codes when running a full scan.
So trying to code the battery, connected on UDS protocol. Following the Ross Tech youtube guide, I try to first change the battery capacity, there is no drop down menu so I have to type in the new value of 70 Ah. However I get following error, "conditions not correct or request sequence error".
Engine is off, push start/stop button is pressed once so ignition is on but engine is off.
Why do I get this message? What am I doing wrong?
Anybody know if the codes mean new parts or if the battery needs to be coded?
