Hi All Audi A8 d4 3.0 2011 owner Rob :) with a quick question if i may
Hi and hello to you all,My names Rob and i've got an Audi A8 D4 2011 3.0 tdi.
Its a bit embarrassing but my wife got in the car to go to her moms yesterday and couldn't get the wipers to work...
I had , five minutes earlier lifted the bonnet and checked the coolant level after changing the aux coolant pump valve the other day (heat problem lol)
Anyway i checked and couldn't get the wipers going so i looked in both side fuse boards and pulled the 30 amp wiper fuse and tested it worked .. nothing..
i pulled a few others at random before i realised the bonnet wasn't shut ..doh !
I shut the bonnet and the wipers worked, great ...but now car wont start and i have huge amount of fault codes.. see below lol
There was absolutely nothing wrong with the car its been brilliant except for the heat.
Ive took all the fuses out and tested them but still get same errors on the dash.
The car wont start , flashing up on screen to put foot on brake when i am doing it and other errors like tyre pressure warning, gear box (can drive but slowly), hydraulic suspension too.. mainly haywire lol.
MMi works fine and dash works fine..
I dont know if i pulled a fuse when the ignition was on ..thats the only thing that worry's me.
Any help would be much appreciated... this car is amazing by he way and i love it :)
These are the Error codes when the car was running fine:
Obtained with Carista 3.9.6 for Android.
Heater & air conditioning:
00378 - Control issuing window right closes
Body/convenience system:
02615 - Locking fuel tank cap
02616 - Unlocking fuel tank cap
Infotainment system:
03276 - Testing Management Software version
03175 - Invalid Dataset
03623
And after it went ape crazy....
ECU info obtained with Carista 3.9.7 for Android:
Transmission
Part #: 4H1927158AA
Coding: 001111 (hex)
Component: 0BK 30 TDIRdW
Fault codes:
12551 Manufacturer-specific code
12554 Manufacturer-specific code
12562 Manufacturer-specific code
ABS
Part #: 4H0907379B
Coding: 60E5A30006A7C500E300 (hex)
Component: ESP PREMIUM
Fault codes:
00089 Line monitoring for clamp 30 starting battery
00160 Adaptation brake booster
00165 Switch for Transmission Position P/N
00173 Key 3 not matched
00179 Access/Start Authorization Antenna, Drivers Side (R134)
00399 Lighting function feedback
00427 Wiring test of the givers for a park assistance
Steering angle
[ECU not present]
Ignition authorization
Part #: 4H0907064BB
Coding: 05B72F00000000000000 (hex)
Component: BCM2 2.0
Fault codes:
01330 Central Control Module for Central Convenience (J393)
Front passenger's seat
Part #: 4H0959760F
Coding: 0038320000047201000001010101102130313131282020 (hex)
Component: MEM-BFS
Fault codes:
01314 Engine Control Module (ECM)
Part #: 4H0820043D
Coding: 3621002800 (hex)
Component: Klima 3 Zonen
Fault codes:
00130 Lighting for door interior grasp back-right (L134)
00311 Tire filler connector
00331 Signal tail wiper wiping wash
Central electronics
Part #: 4H0907063L
Coding: 26002010C034AFE18B810007A0001D0C409DC30A07010101800008402000 (hex)
Component: BCM1 2.0
Fault codes:
Parking/steering assist
Part #: 4H0919475H
Coding: 300302 (hex)
Component: PARKHILFE ACC
Fault codes:
12648448 Manufacturer-specific code
Auto-leveling suspension
Part #: 4H0907553C
Coding: 008000 (hex)
Component: LUFE-DAEMPFER
Fault codes:
00022 Actuator warm flap center console in the back on the right of (V201)
00020 Actuator shut-off valve Defrost and Dashboard Vents right (V199)
00019 Actuator warm flap (V198)
00021 Actuator shut-off valve Defrost and Dashboard Vents left (V200)
00648 Oxygen Sensor Heating Circuit - Behind Catalytic Convertor
Airbags
Part #: 4H0959655C
Coding: 30314246323430303038554A305234483053 (hex)
Component: Airbag10.43
[No fault codes]
Steering wheel
Part #: 4H0953568A
Coding: 000034 (hex)
Component: Lenks.Modul
[No fault codes]
Instrument cluster
Part #: 4H0920910D
Coding: 27AF08001B002600010000 (hex)
Component: TDieGB-------
Fault codes:
16776971 Manufacturer-specific code
CAN network gateway
Part #: 4H0907468F
Coding: 00CD077D00 (hex)
Component: J533--Gateway
Fault codes:
04224 Manufacturer-specific code
Additional functions 2
[ECU not present]
Driver's seat
Part #: 4H0959760F
Coding: 00383B0000057201000001010101102130313131202020 (hex)
Component: MEM-FS
Fault codes:
Driver's door
Part #: 4H0959793F
Coding: 011F12205E21628202080002 (hex)
Component: TSG FA
[No fault codes]
Part #: 4H0907064BB
Coding: 011B0E2200B93C81B320C784080100000000000000000000000000000000 (hex)
Component: BCM2 2.0
Fault codes:
Front passenger's door
Part #: 4H0959792F
Component: TSG BF
[No fault codes]
Parking brake
Part #: 4H0907801E
Coding: [none]
Component: EPB-4
Fault codes:
333568 Manufacturer-specific code
334080 Manufacturer-specific code
331264 Manufacturer-specific code
331520 Manufacturer-specific code
331776 Manufacturer-specific code
Headlight aiming
Part #: 4H0907357A
Coding: 11116F101000A300 (hex)
Component: ....LWR12....
Fault codes:
00095 Engine for central locking, door in the back right, LOCK (V215)
336388 Manufacturer-specific code
Radio
Part #: 4H0035061R
Coding: 010103020100000001 (hex)
Component: Radio U DAB
Fault codes:
03278 Function-Limitation because of lacking info
Infotainment system
Part #: 4H0035646A
Coding: 020101000001F1EF45108B1E00000003E00001000000000000 (hex)
Component: H-BN-EU
Fault codes:
03276 Testing Management Software version
03175 Invalid Dataset
03623 Manufacturer-specific code
Rear left door
Part #: 4H0959795B
Coding: 010F12204021628202080002 (hex)
Component: TSG HL
[No fault codes]
Back-up camera
Part #: 4H0907441
Coding: 1022002 (decimal)
Component: SG Rueckfahrkame
[No fault codes]
Trunk
Part #: 4H0959107P
Coding: 0210044000 (hex)
Component: HDSG-Modul
[No fault codes]
Part #: 4H0907412
Coding: 220000 (hex)
Component: ALM
Fault codes:
00090 Supply line clamp 30 starting battery
Rear right door
Part #: 4H0959795B
Component: TSG HR
[No fault codes]
Sensor electronics
Part #: 4H0907637
Coding: [none]
Component: SARA 6D
[No fault codes]
Seatbelt pretension (front left)
Part #: 4H0980945
Coding: 00060000031F030000030800424CDA010000 (hex)
Component: RGS-VL
Fault codes:
12583691 Manufacturer-specific code
12583692 Manufacturer-specific code
Seatbelt pretension (front right)
Part #: 4H0980946
Component: RGS-VR
Fault codes:
Gear selector switch
Part #: 4H2927731A
Coding: [none]
Component: GSM-RL
[No fault codes]
Re: Hi All Audi A8 d4 3.0 2011 owner Rob :) with a quick question if i may
Omg get yourself some proper diagnostic scanner, vcds the best , u need erase all errors .i noticed one error from can gateway ' ecu not connected' - did you put fuse back in correct slot.? I am asking that because i have done that in past and i had all error lights on my dash. Maybe fuse from ecu you put back in different slot and thats why u having so many errors .
Sent from my ONEPLUS A5010 using Tapatalk
I read through log again , that carista didn't scan ECM so it couldn't connect to ECM , and several other modules in car indicating that Engine module doesn't get power(ecm not present), so check the fuses again and pray that you put fuse back in wrong slot , otherwise ecm is damaged
1 Attachment(s)
Attachment 36340Lol yeah ive wanted vcds for ages..just abit skint at the moment..
could very well be fuse in wrong place .. im rechecking all the fuses to the manual and i have no 35 amp fuse in slot 4 ..powe supply(engine components)
i have never seen so many codes!
is it possible water has got into the Convenience Module somewhere? Just enough to stop stuff happening?
And as above, have you checked the fuses are back in the correct locations? And recorded and then cleared the codes?
Have a look on here or on eBay, as there are people offering to use VAG-Com to clear and/or interpret the codes for you.
Ah, just seen your reply...
hope it is that...
2 Attachment(s)
here are the fuseway numbers and picture of my actual fuses number 4 is missing..would it hurt if i pulled a 35 amp out the washers and stick it in number 4 ?Attachment 36341Attachment 36342
yeah lol ...its not water .. i started the car and drove it just before i pulled the fuses so i know its something stupid i did with the fuses lol
i tried to clear them with carista and it does but they pop straight back again
1 Attachment(s)
Just put fuse in there , spare one , dont use one from different module, get spare one from second car or just buy it
