1 Attachment(s)
3.0TDI Quattro DSG fault code
Had the gearbox warning light flash on for half a second this morning; scanned with VCDS this evening and found this fault code
Attachment 36163
The light went off as quickly as it came on. Car drove absolutely fine to work and again on my way home this evening; both in normal, sport and manual modes.
A quick search seems to indicate some sort of activation solenoid / motor?? Or is it pointing to a failing mechatronics??
Car has done 119,000 miles and had the gearbox replaced at 72,000 miles just before I bought it. Had the DSG serviced last year at 38,000 miles as per service schedule. This is the first and only time I’ve had an error code
Re: 3.0TDI Quattro DSG fault code
I wouldn't panic, clear the fault code and see how you go. Random issues can show up on any of the cars systems.
