Re: 2011 Golf 1.6tdi issues
So you have fitted a matched set components from a dead car, engine ECU, dash pod but what do you mean by ignition and control module? Have these had the cars VIN entered to disable component protection? You can't work on modern CAN BUS cars in the way you could say a Golf 4, it doesn't work. Without your own diagnostic system (not just a code reader) you are not going to solve this even by throwing every possible part at it, you could solve the issue but not know simply because you can't see and clear codes in the CAN BUS controller.
Hi there did u ever find fault with the car I have same issue thanks
