Re: Number plate light/lens
The item you have linked is 2 full units with bulbs but in white plastic as they are not OE style.
This is OE style for one full light unit
https://rover.ebay.com/rover/0/0/0?m...2F264230304267
Cheaper still
https://rover.ebay.com/rover/0/0/0?m...2F323785856915
They clip in and the lenses are not normally available separately so sold as complete replacement units. £12 to £20 each isn't so bad for genuine parts therefore.
1 Attachment(s)
Thanks, but even those don't match what are currently on the car. I will attach a picture that maybe shows more, but there doesn't seem to be a unit that can be easily removed, rather the lenses themselves just "slot" into place and are held in by two screws. I presumed only the plastic part is what I needed as that contains the terminals that have corroded on my old one.
I have managed to find an eBay listing with just one lens that exactly matches what is currently fitted (VW PASSAT B5 B6 TOURAN TRANSPORTER T5 MULTIVAN NUMBER PLATE LAMP LIGHT 3B5943021 1002111305684 | eBay), but that does work out more expensive per lens than buying the pack of two.
Attachment 36016
It is also worth mentioning that it is an estate which I think does make a difference as the saloons had a different style of light from what I have managed to piece together.
Quote:
Originally Posted by
jmurray01
Attachment 36016
Ah estates are slightly different, and have the same unit as the T5. Part number 3B5943021E which was discontinued in 2012 but still available to buy whether genuine or aftermarket.
https://www.ebay.co.uk/itm/VOLKSWAGE....c100930.m5375
That explains it then! Thanks, I will order one of those.
