1.9tdi touran has this sound for a couple seconds just after it's started. Any ideas what the problem is.
Ive added a video of restarting it a few times
http://youtu.be/J8WSW5EbqBg
Printable View
Starter motor ?
Just by chance today I was walking past a Beetle when it started. Fired straight away but then made a noise I've not heard in years, normally associated with 1980's Fords, but I can't remember the exact cause. It was either the bushes on the starter rotor gone or was as the pinion on the starter runs back down the shaft if it's worn.
it was the starter, different from other touran i had experieced same fault. again starter had broken up, alot of play , alloy housing broken up
My Octavia does it and so do many VAG cars from the noughties, it comes and goes and gets really bad if the DMF is chucking crap out.
