Can anybody tell me where to find diagrams, pictures, electronic circuit or other information about the control unit for VW Sharan highline AUY motor from 2002 model?
Printable View
I'm sorry but I could not find anything of help on that adress.:confused:
When I click on the adress, I login and then I can not find the information you are trying to give me.:zx11:
Where is the misstake?:confused:
It is there but I don't think it is what you want. Do you want internal diagrams of the climate control system or the wiring to it? The latter is what I have already sent.
Yes, you've allready sent me the lectrical diagrams for the heated windscreen circuit.
In order to check possible problems on the control unit, I need a drawing, diagram, something to chech it.
The unit control is the box where the fuses are in and where all the cables are connected to.
I think maybe the control may have some problem (internal relay or maybe soldering cracks?).
The only other relevant diagrams I have are for the Basic Equipment and the Climatronic unit which is referred to on the heated screen diagram as J255. The fuses are all located in the box on the battery or in the fuse box inside the cabin. PM me your chassis number and email address again and I will send you the Climatronic and Basic Equipment wiring diagrams plus an illustration of the battery fuse box. Have you have a diagnostic scan done on the Climatronic unit?
