Re: Mk4 Golf GTI 1.8T 20V
It sounds like no circulation even though the pump is new. Ignore what the dash gauge says, it is completely irrelevant to what is going on except that at one point it will be right, a bit like a broken clock is right twice a day. The only way to know what is going on is to be able to see what the temp sender is saying using a diagnostic system with live data viewing and even then that could be wrong as the sensors are a common failure. The thermostats on these tend to stick open, the one on my Octavia VRS is stuck open but I have not had the time or energy to change it. Where did this water pump come from and do you have any paperwork or the box? Do the fans come on? If not, do they come on when you put the AC on.
