Last week the car broke down.
A red warning light came on with several loud beeps. The idle was slightly faster than normal and when I pressed the accelerator peddle there was mainly no response, occasionally it would rev.
I hooked up my Vag com and one of the results was:
18047 - Accelerator position sensor 1/2 (g79/G185)
P1639 - 35-10 - Implausible Signal - Intermittent.
The RAC man that came out got the same result and assured me completely it was the accelerator peddle itself, it being the electronic kind.
I got a second hand one form ebay that was assured was fully working and fitted it; this failed the fix the problem and the exact same problem was there.
What else could this be? is the car not recognizing the 'new' peddle.
Audi A4 B5 Avant year 2000 AJM engine.
Vag Com faults found:
2 Faults Found:
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185)
Readiness: 0 0 X X X
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D57
Coding: 00044
Shop #: WSC 06325
VCID: 2E53E833EAE29E6E36F-2566
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06325
VCID: 2F6DF537EDE897663D9-4E42
4 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
VCID: E0CFC60B60B6F81E743-4A3A
2 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
27-10 - Implausible Signal - Intermittent
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
27-00 - Implausible Signal
