Re: Tiguan Gear Shift Handle
go to VW Parts Department & ask
They should with a bit prompting got to the mechanics and ask
The only problem I see is that the housing for the handle might be different and not hold the different stick.
If it does fit, then the next problem might be the wiring connector is different, if so it is hopefully two wires and they can be soldered. It should in theory be just two wires as its just a simple switch
Or you splash the cash & get a newer model
Thanks Niall
Hadn’t thought of any wiring, thought it was a mechanical button.
I’ll pop into VW later today
