Rear right door does not open
Hi.
I have a keyless Q5 2009 with a door lock that started to give me problems. Sometimes it was not possible to unlock the door from the outside, the door was only unlocked when i pulled the inside handle.
This has happened before on my driver door and the solution was to replace the door lock. I guess the small motors inside the door lock got bad.
I was about to change the door lock on this rear door, but then i got a second problem and now the door does not even unlock when using the inside handle. It is like the child lock has kicked in without anyone using the proper procedure with the emergency key.
So i can not unlock the door using the key, the door unlock button at the driver seat, from the outside handle or when pulling the inside handle. As i have keyless there is no place to put any emergency key....
Anyone knows how to get access to the inner door on a Q5?
Found this thread for a Passat:
https://www.vwaudiforum.co.uk/forum/s...-open-HELP-Plz
BR
Bolleboll
