I have a 2007 Passat 2.0 TDI DSG
Could someone tell me where I can locate the Glowplug relay please.
Printable View
I have a feeling that you will find it in engine comp fuse/relay box !!
I might just have got that wrong--relay box under drivers side-pos -behind the glovebox !!
Will take a look tomorrow, but can’t find any literature showing which one it is. Did read somewhere that it’s under fuse box in engine compartment.
workshop-manuals.com--you prob find what your after, it covers all, and it is free !!!
It is under the engine bay relay/fuse box and you can see it with the air filter out but to property get at it the fuse box has to come out which is quite an involved job, you have to strip down the front fuse layout first (known as SA) and then you turn the centre Torx nut in the relay plate (called SB) which disconnects the box from the connector block below. PLEASE disconnect the battery first......
