Re: Help intepreting output
there are two communications paths with the MOST bus systems. The first is a communication from the CAN controller to each of the other controllers where status can be obtained. The first OK on each module shows that the status is OK on each. It means, the module has power and can talk back to the Gateway.
The MOST also has a token ring optical bus. The place you see the errors indicates that there is a break in communications. The Message starts at the CAN controller. It is passed to the Control Head. The OK indicates the Control Head saw it so it passed it on to the Media Player. It too saw the message. So it passed it to the Sound System. The Sound System did not get the message nor did the Radio, nor did the Nav and it did not make it back to the CAN gateway... All those show error.
So your problem lies between the Media Player and the Sound System.
There is an optical bus loop tester that allows you to eliminate a control module from the optical loop...
