Judder on acceleration only - 2008 VW Golf 2.0 TDI 140 BKD
Hello
I have bought a 2008 VW Golf 2.0 TDI 140 BKD and it has a judder when accelerating only from 1500 to 2500rpm, which gets worse and worse in higher gears. I have taken it to several garages and the only error code is for low pressure in air con when plugged in to diagnostics. So far I have tried:
1. Rebalanced wheels and 2 new front tyres.
2. Engine mounts checked.
3. Drive shafts checked for true running, gators removed and regreased.
4. New injector wiring loom.
5. New Dual Mass Flywheel/clutch
6. New head gasket with new cam belt and water pump.
7. 2 faulty injectors refurbished.
The car has a full service history with fuel filter being changed every 2 years.
This has cost me over £2000 so far and the judder persists. The car is only worth about £3500, so any help would be greatly appreciated?
Re: Judder on acceleration only - 2008 VW Golf 2.0 TDI 140 BKD
Does it do it when just light acceleration or any ? I have this fault and mine is worse in the rain ?
The garage fixed it mostly. I have a horrible feeling it was just the EGR valve that needed cleaning out properly from carbon deposits. However, the garage said it was the injectors - maybe it was or maybe they couldn't admit it was something as cheap as the EGR valve cleaning... I will never know..
It used to do at 1500 -2500 rpm - gentle or flooring it... worse in higher gears....
Good luck..
Yeah, see if I floor it mine is okay, doesn't pull as good as it should in my opinion, I really don't know what to do
