Q7 retrofit LED Fog Light Bulbs
Has anyone installed LED fog light bulbs?
The standard bulbs on my 2012 Q7 look out of place against the LED side lights so I want to repace but want to make sure I get the correct spec.
I've seen these on eBay which supposedly fit a Q7...
https://www.ebay.co.uk/itm/351596569256
Re: Q7 retrofit LED Fog Light Bulbs
You probably want to make sure you get CANBUS bulbs so they don't throw errors.
I've not used these but they say they will work: 2 X H11 68 SMD CANBUS FOG LIGHT LED BULBS ERROR FREE XENON WHITE H11 FOGLIGHT | eBay
p.s. They look very much the same as the ones you listed but your link doesn't say anything about being CAN BUS compatible.
I have a hid kit within my fog lights. Look awesome
Can someone advise the smartest way to remove the s line fog lamp grille to get to the light?
Any ideas on why this type is different to those supplied without a wiring
https://rover.ebay.com/rover/0/0/0?m...2F112033280043
