G17 (outside air temp sensor) location help!
Got an error on my climate control diagnostics- I get an error for Outside Air (Ambient) Temperature Sensor (G 17). According to everything I can find on a LCR the sensor should be near the passenger foglamp. Instead there is FMIC piping there! I looked in that area and all I have is the wiring for the foglamp that was removed and the wiring for the horns. I do not see the sensor anywhere! Where does the wiring for the G17 start at? I figure if I can find that I can trace to where the previous person that installed the FMIC tucked it away at!
Re: G17 (outside air temp sensor) location help!
Well on a vw golf it's on the nsf so it's probably the same on the leon. If you can't find it take the bumper off there will be 2 wires to it and it will be there on the slam panel loom.
Sent from my SM-G900F using Tapatalk
Quote:
Originally Posted by
Which Leon?
2004 Leon Cupra R
It is down in the left front corner of the bumper under the air intake above the spoiler.
The sensor is 1J0 919 379 A and costs £31.72, the plug is 1J0 973 702 and costs £3.79 and into this you need 1 double ended yellow repair wire 000 979 019 E which is £5.04 (there are EA and FA gold plated and gold plated with galvanised wire respectively alternatives) and the wires should be sealed in the plug with rubber boot 443 906 102 G which is £6.32. This repair (sans boot) is what has already been done with the other plug. The repaired brown/yellow wire goes into location 1 of the plug and the brown/white into location 2.
