Has anyone actually got the QI charger to work with ANY phone ?
I have a samsung S6 which works fine with a Samsung QI charger and is listed by Audi as being compatible, but will the QI charger in the car work with it........ will it "&)$"..
Anyone else got theirs working ?
Re: Has anyone actually got the QI charger to work with ANY phone ?
Worked perfectly with my LG G3.
Works fine with my iPhone 6 and the Audi case.
The case doesn't work with any other QI chargers though unfortunately!
Samsung s7....works fine, really handy.
OK Thanks, Must be my S6.. Ill try someones else's phone in the week to be sure..
I've got an 2016 A6 Avant with tech pack and Audi phone box. I bought the wireless charging case from Audi to use with my iPhone 6 but I put it in the phone box but it won't charge. It will charge with the cable. Is there anything to change in the phone or the MMI? If not either the case or phone box must be faulty.
Nothing to change, sounds like faulty part.
Sent from my SM-G920F using Tapatalk
Are you 100% it has the correct charging port, I thought my MY16 had the port, but I could not get the phone to charge. On my MY17 the phone charges and the plate looks different to the MY16 version and I've also got charging options in the MMI menu.
http://i1339.photobucket.com/albums/...psfxzrlapy.jpg
MMI Setup menu, you also get a battery icon in the bottom of the display when charging (next to the Bluetooth icon)
http://i1339.photobucket.com/albums/...psmbv8eohv.jpg
http://i1339.photobucket.com/albums/...psyjglst46.jpg
The rubber mat in my car does not have the 'qi' symbol, only the 'antenna' symbol. The MMI does not have the options shown in your photo (many thanks for taking the trouble). I checked for system updates and am in the process of downloading a service update. I'll see what happens. I bought the case (£35) because it said it worked with the Audi phone box installed in car I had. It can go back if it doesn't work. Many thanks.
