Car starts and dies immediately
Hi, new to the forum and have a question. I have a mk4 golf 2000 115 gttdi! It starts up but then dies immediately. I know that the common issue for this is the immobiliser so it has now been mapped out of the ECU but it still does the exact same thing. The immobiliser light does not show on the dash and was doing this prior to it being mapped out. Any suggestions?
Re: Car starts and dies immediately
Check for fault codes via vag com
Sent from my LG-D855 using Tapatalk
Agree with that - needs a scan at the least.
Has the ignition switch ever been replaced? You need to check the feeds from it - voltmeter at the ready.
Replace the Main power Relay 109 Main power relay this causes your described symptoms and many more.
Relay 109 supplies power to:
- Glow plug relay
- Fuse 32
ECM
Fuel quantity adjuster
- Fuse 34
Cold start injector
Waste gate bypass regulator valve (N75)
Change over valve (N239)
EGR vacuum regulator valve (N18)
Mass air flow sensor (G70)
- Fuse 43
Clutch vacuum vent valve (if equipped)
Brake vacuum vent valve
Relays for preheating coolant (if equipped)
Crankcase ventilation heating element
The ECM supplies power (and sometime ground as well) for:
Fuel cutoff valve
Cruise control switch
Manifold (intake) air pressure/Intake air temperature sensor
Needle lift sensor
Engine speed sensor
Engine coolant sensor
Closed throttle position switch (part of "go" pedal)
Kickdown switch (part of "go" pedal)
Throttle position switch (part of "go" pedal)
Fuel temperature sensor
Modulating piston displacement sensor
The ECM also communicates to the instrument cluster electronics and transmission control module (on automatics).
As a result of this, you can see why if the relay starts to cause power to flicker, or voltage drops, for all of these components, the results can be "unpredicatable" and none of them desireable. |
