Bluetooth locked "Please wait..."
first of all.. sorry for my bad english. A friend suggested me to post here my problem because it seems yours is the best forum for Audi owners.
I searched a lot in the forum without finding a solution to my problem.
I really hope you can help me to understand the problem (already asked in many forums but without success).
I try to explain:
Car: Audi A4 B8 '09 with original Bluetooth. No MMi, Audi Concert.
Bluetooth worked well for years.. now it is stucked.
Trying to connect a mobile phone, I got the permanent message in the display "Please wait..."
Phone is connected (if I use the phone to reply to a call audio is ok from car), but I'm not able to answer/hang up calls with car, search number, show calling number, and phonebook is not available. When I turn the car off.. it loose pairing and I have to search car again.
What I noticed is that when bluetooth was ok, bt name was something like "Audi UHV 0897", now bt name is "Audi UHV 0000"
Just tried:
- reset phone settings from Audi "setup"
- tried with many phones (android, iphone, old nokia)
- disconnected car battery for more than an hour
I had no luck: always the same problem.
A friend used the original ross-tech diagnostic software and this is the faults found:
Code:
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 77: Telephone Labels: None
Part No SW: ##H BAS 060 0 HW: ##H BAS 060 0
Component: FSE_256x BT H34 0600
Revision: 00000001 Serial number: 00000000000000
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 2A5BE423850AF24EEA7-807F
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 98470 km
Time Indication: 0
Date: 2016.07.06
Time: 11:29:22
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 98470 km
Time Indication: 0
Date: 2016.07.06
Time: 11:29:22
In telephone, "01042 - Control Module; Not Coded " is quite strange.. isn't it?
Many thanks for your attention
Re: Bluetooth locked "Please wait..."
It looks like your telephone module is faulty. Even though it says it's not coded, there are no Serial Numbers / Coding being read and its only showing one occurrence of the fault. I could be wrong, you could try recoding it by copying the coding from another users phone module with the same specs to yours. FSE_256x BT Ebay link
http://uploads.tapatalk-cdn.com/2016...308759c6e1.jpg
I am having this problem for a week now. Vcds shows no faults
