AMI retrofit VCDS coding (Pre facelift)
Since my car is going for a service I'm going to ask them to do a couple of things for me.
I retrofitted AMI a while back and can see some instructions on coding changes for facelift A6's but none for the pre facelift. Is there anything that needs to be done?
Re: AMI retrofit VCDS coding (Pre facelift)
How did you fit the AMI module, did you remove the CD-Changer?
Media Player 02 should be selected on the can-gateway. No other coding is required.
Awesome, thanks for your help.
Quote:
Originally Posted by
B5NUT
Please can you explain this in a bit more detail? Thanks
markaz
There's nothing else to it?
markaz
Enable the appropriate box in the installation list within can gateway module via VCDS.
Link:- Ross-Tech: VCDS Tour: Gateway Installation List
