Re: Strange clutch issues
you don't mention your mileage on the car
the noise changing gear could be your thrust bearing, can you hear it in neutral and engine ticking over ? Does it change note when you press the clutch all the way down ?
Noise could be springs on clutch also
does your car have a clutch cable or hydraulic fluid ?
Quote:
Originally Posted by
niall campbell
Sorry forgot to mention the mileage - 185k. A very patchy service history with nothing prior to a year before i bought the car. Possibly the original clutch?
It's not a noise when changing gear but a noise when idling which changes when the clutch pedal is depressed, I assumed it was the DMF starting to chatter.
Clutch is hydraulic. I was going to change the brake fluid which I believe the clutch runs on as I have no record of that being changed. Could it be old brake fluid causing the slave cylinder to stick and not release fully?
could be the slave cylinder leaking if its internal in the bellhousing ............................... which you want to change if you change clutch, if internal
At 185K I would change the clutch , probally nearly worn out, rattling springs, down to rivets etc.
Usually if ticking over and you hear a rattle/ noise , then fully depressing clutch changes the noise, its the thrust bearing
with my A6, I have to drive the car silky smooth. Sometimes clutch judders for no real reason, sometimes after towing my horsebox ......................... I have years of towing experience............... then after a couple of days it clears itself.
You may be finding this is what is happening, mine doesn't slip, just its juddery
Park the car on a steep hill. Put the car in 3rd gear and try to pull away. The car should stall. If it revs up but doesn't go anywhere, the clutch is slipping. Its easier to do than explain
Agree with niall here, sounds like dmf and clutch due for replacement at that age and mileage.
Agree, as already mentioned by other members, you best of replacing the whole clutch kit including flywheel. You can buy an LUK clutch & DMF for around £250
Oh, and make sure you don't forget to renew the clutch release bearing sleeve, under a fiver.
