Does any one know what "KEY WARNING ACTIVE " is/does , it can be found in "46 Central Conv" ,"Byte 9"
on my car it is unchecked.
pls see image Attachment 29714
Printable View
Could be the warning in FIS when your key leaves the car when ignition is on or engine running "Key not in vehicle".
Thanks for the response , I don't think it's that , as my box is unchecked (not active) and when I leave the vehicle with my car key and the engine running the Warning "Key not in vehicle " comes up?
Wondered if it's a Low battery warning for the key - if battery gets weak in the key fob it warns you in the drivers display ?
Hmmm... might be. I do not remember seeing this bit, have to check with the latest VCDS.
