My A4 S Line with 20mm drop Eibach question ?
I have been thinking of swapping my 19" alloys for 18" to improve the ride but after reading many threads I might look at trying to tweak the suspension first , I am pretty sure I have the sport springs as I tried measuring from center of rear wheel to arch and its about 370mm and I think the s line option is 360mm ? The only thing is that although I seem to have to slightly more forgiving set up I would still like it a tad softer :Blush2: I know that Eibach do the Pro Kit with the 30mm but will this just lower it another 10mm than I already have and make it a bit stiffer , I liked this set up on a previous car I had that I used to track day in as the springs had some give before they would load up in the corners ( hence progressive ) the only thing is I don't really want to go lower if its not going to improve comfort .
Does anybody run this set up and what do they think ? Or the Eibach Sport-line kit which is a 20mm drop ? As I don't have any experience with these ones , thanks for any pointers as long as its not to buy an SE :D
Re: My A4 S Line with 20mm drop Eibach question ?
S line suspension is very poor and crashes over bumps. My S line mk2 TT was the same and changed to Eibach pro kit and was such a nicer ride. Changing from 19 to 18 will be hardly any difference to be honest.
Quote:
Originally Posted by
dubvrs
Ok ok thanks but did your TT originally have the sport suspension with 20mm drop or the s line option 30mm drop ? I.e was it lower after fitting the eibachs or the same height ? Thanks again.
I looked into it and it looks like the eibach Pro kit will lower my sport suspension a further 10mm bringing it the same height as the s line 30mm option .
But what I really need the know is will it also improve the ride quality even though it's 10mm lower ?
also could I just fit se springs straight on with my shocks if I wanted ?
thanks for any pointers.
