A5 gearbox and diff oil change?
Hello everyone good to be part of this forum. I have a technical Q about changing the oil I would like to know where the drain and fill plugs are located ? I have just purchased 5 litres but its in 1 single container, will I need to use a 1L squeezer to fill both and could do with knowing what quantities in each? and as title says where are the fill and drain plugs are? 2008 3.0 tdi Quattro- possibly covered before please point in the right direction (other than FWD) nice one cheers for any help!!
Re: A5 gearbox and diff oil change?
Before you start anything have you got VCDS as you'll need it.
Which diff, there are 3? Which gearbox, manual or auto?
hi, yes I have VCDS, and its the 6 speed manual gearbox, don't know what gearbox code is it on the label in the service book/trunk ?
sorry but can you confirm the oil for both rear diff and gearbox are the same 75w 90 fully synthetic ?
gearbox code is KMU & rear final drive is JKQ?
Any help to confirm the detail above would be really appreciated - Nice one.
VAG don’t specify what it is but the transmission fluid shown for the type 0B4 KMU code box and its integral front and centre differentials is G 052 911 A1 or A2 (3.8 Litres dry capacity) which Febi specify as being
API GL-5, MIL-L-2105 D, MTF LT-2, MTF LT-3, SAE 75W-80, Yellow, Oil Viscosity Classification SAE: 75W-80 for manual transmission
The rear differential type 0BC code JKQ oil is listed as G 052 145 S2 or A1. And is described by Febi as
GL-5, SAE 75 W 90, SAE 75W-90, VW 501.50, Yellow, for manual gearbox and rear axle differential
The gearbox oil filter plug is on the left side of the gearbox directly below the clutch slave cylinder.
