Green Menu - values for Univ. Garage door opener?
Just finished retrofitting Homelink in my 2011 A7.
Enabled garage door opener in green menu car/cardevicelist.
But I also need the green-menu univ. garage door opener-values for both car/carmenuoperation and car/carbusassignment.
Any A7-owners with Homelink out there who can find out these two values for me?
Re: Green Menu - values for Univ. Garage door opener?
If you can tell me how to get the information, I will get it for you. i have vagcom
These values are found in Green Menu. (Press "Car"-button (so it will light red). Press and hold "Car" and "menu"-buttons for approx. 5 sec. to access green menu. To exit menu, press "Car"-button).
MMI-system must be fully loaded before one can enter green menu (approx. 1-2 min. after turning on ignition).
If green menu is not enabled in your car, you can enable it with VCDS, more info here; Enable MMI hidden green menu (2G, 3G, 3G+) - mr-fix.info (in the 3G/3G+ -section)
Quote:
Originally Posted by
shabazmo
Here are my findings so far, I would appreciate if you could compare these:
I have enabled Garage door opener three places:
#1: 5f Information Electr. -> Coding -> Byte 9, Bit 2 (I think this is the direct connection to toggle menu item "univ. garage door opener" in green menu car/cardevicelist)
#2: 09 Cent. Elec. -> Coding -> Byte 23, Bit 5 "Garage Door Opener installed"
#3: 46 Central Conv. -> Coding -> Byte 6, Bit 6 "Garage Opener installed"
Green Menu: Item "univ. Garage door opener" in menus "car/carmenuoperation" & "car/carbusassignment", currently have the values "5" & "[Clamp 15] 8/9". Can you please compare?
Thank you.
shabazmo
Could you please send me an auto-scan so I can compare values? Thanks ;)
