Audi A4 (B5) 1.9tdi Estate Instrument Cluster SNAFU
Evening all,
On my A4 1.9tdi (B5) the instrument cluster seems to have a fault wherein the gauges do not work (Revs, fuel, temp & speedo) and a central locking indicator appears in yellow. The fault code it is kicking out in VCDS Lite are as follows:
Code:
Address 01: Engine Labels: None
Controller: 038 906 012 AJ
Component: 1,9l R4 EDC 0000SG 2829
Coding: 00002
Shop #: WSC 06435
VCID: 58C30B63AB0B
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-00 - -
Readiness: N/A
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Controller: 8D0 920 950 E
Component: KOMBI+WEGFAHRS. M73 D51
Coding: 00440
Shop #: WSC 00000
VCID: 2A2781ABC5E7
XXXXXXXXXXXXXXXXX AUZ5Z0Y6254236
2 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 16174
Shop #: WSC 06435
VCID: 2F1190BFFE05
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
01134 - Alarm Horn (H12)
49-00 - No Communications
Can anyone suggest an easy fix? or is it a salvage / new instrument cluster required? If this is the case is a trip to a main ******* required or can it be recoded using VCDS or similar?
Thanks in advance. Oh and Hi, I'm Dan by the way :)
