Electrical gremlins / where are the ecu's on a vw touran?
Picked up an 05 plate tdi touran off a neighbour. It's been sitting for about 9 months due to turbo problems.
I'm getting some electrical gremlins so thinking damp has got to the various ecus so would like to take them out and dry them off.
Does anyone know where the ones that control the steering wheel and the abs are located?
There's a few issues:
ABS/ESP or whatever it's called light is on once the engine starts but goes out after a very short distance (no faults with brakes on computer)
The steering wheel light comes stays on as orange/yellow and then does the same as the above (only a recent thing)
The front wipers only occasionally work (no pattern to this) but the rear one always works. They also dont 'jump' when the engine goes on or off
code read it with vagcom and it gave the following:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 250
Reset counter: 255
Mileage: 254374 km
Time Indication: 0
Date: 2000.00.00
Time: 08:14:38
Freeze Frame:
RPM: 2520 /min
Speed: 91.0 km/h
Load: 80.8 %
Voltage: 14.29 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
and
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005754942
Coding: 00890F2100040F0000120C000000000000087B075C
Shop #: WSC 01324 785 00200
VCID: 2A5BD3FC855D6C7111F-807F
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 110506 020 0501
Coding: 00038805
Shop #: WSC 01324
1 Fault Found:
01049 - Supply Voltage Term 50
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 186
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 6.70 V
OFF
ON
ON
OFF
OFF
Does anyone have any advice?
Thanks,
steve
Re: Electrical gremlins / where are the ecu's on a vw touran?
Quote:
Originally Posted by
flat4fanatic
What was the trouble code in the steering wheel electronics? Maybe that will give you a clue what the trouble is.
The steering electronics ECM is under the steering cowlings and the ABS ECM is attached to the ABS pump module near the N/S bulkhead in the engine bay
Jim.
Hi Jim, thanks for the reply.
the fault was possibly the cruise control:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 035 0070
Coding: 0000042
VCID: 74E70D8417196A817B3-8021
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective - Intermittent
