Help with Antenna & Aux Heat. VCDS Faults
Hello, I am hoping that someone may be able to help me with interpretting a couple of errors that I am seeing in my VCDS report for my 57 Plate Q7 S-Line? The first appears to be an issue with the Radio Antenna and the second is with the Aux Heat. I have tried clearing both faults, but they both come back up immediately. It would be great if someone could point me in the right direction to fix these errors.
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388AT077583250
Coding: 0000001
Shop #: WSC 31414 790 00001
VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
00856 - Radio Antenna
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 17
Reset counter: 77
Mileage: 136993 km
Time Indication: 0
Date: 2014.11.27
Time: 18:33:29
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06C148065
Coding: F5DBFF7F307202
Shop #: WSC 00134 210 88439
VCID: ECD7A23BCF7EAC7ED8B-80B9
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 137300 km
Time Indication: 0
Date: 2014.12.05
Time: 17:29:50
Many thanks,
David
Re: Help with Antenna & Aux Heat. VCDS Faults
00856 - Ross-Tech Wiki
Code:
00856 - Radio Antenna: Open Circuit
00856 - Radio Antenna: Short to Ground
Possible Symptoms
Radio Tuner not working
Possible Causes
Wiring/Connectors from/to Radio Antenna faulty
Possible Solutions
Check Wiring/Connectors from/to Radio Antenna
Check Radio Antenna
Aux -
004 - No Signal/Communication means simply that, no communication with the module. Suspected failed?
