Passat 2012 TDI 2.0 DSG 6 - Starter Relay
My car has problem to start. When i insert the key and press the start button it doesn't fire up the start engine. The battery seems to be ok. All lights are ok and NV510 works. The car does not warn for low battery either. So I have checked for errors with VAG COM and i found this:
Quote:
Friday,26,December,2014,22:21:09:58797
Quote:
VCDS Version: Release 11.11.5
Data version: 20121222
Address 01: Engine Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 BD HW: 03L 907 309 N
Component and/or Version: R4 2,0L EDC H24 8244
Software Coding: 001D0032043401080000
Work Shop Code: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018BD 003006 (VW46)
VCID: 6DDBA241BC745370FAA
1 Fault Found:
5453 - Starter Relay
P3088 00 [039] - Electrical Malfunction
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 112937 km
Date: 2037.14.30
Time: 21:27:44
Readiness: N/A
It seems to be a problem with the starter relay. Is this famous problem for passat 12? What can you do about it, can you replace the starter relay or does anyone have any tips?
Regards,
Eriikoo
Re: Passat 2012 TDI 2.0 DSG 6 - Starter Relay
Quote:
Originally Posted by
eriikoo
Hi, My car has problem to start. When i insert the key and press the start button it doesn't fire up the start engine. The battery seems to be ok. All lights are ok and NV510 works. The car does not warn for low battery either. So I have checked for errors with VAG COM and i found this:
Subj: Passat 2012 TDI 2.0 DSG 6
Three year warranty from new. Dealer to fix.
Yes i took it on the volkswagen mobility guarantee. They fixed it a relay was broken. €15 for the relay and €100 for the repair cost. They took it on the warranty. :)
Does your invoice say what relay, part number, etc?
May help someone in the future
