Hi guys, quick question - the black hose pictured below is that part of the vacuum pump?
Also should it be bouncing up and down when the engine is running e.g popping in an out?
Attachment 23295
Printable View
Attachment 23295
Someone on youtube with the same problem.
http://youtu.be/vExqaEZ23PA
That looks a vacuum hose, looks like there's wear on the connection. Secure it with duct tape until you get it fixed
Checked it again this morning and its stopped popping in and out, however if I sit parked up when the engine is idling if I pump the brake pedal the idle rpm goes up, each time I press the brake pedal the engine rpm increase by about 100 rpm.
Hence the duct tape until you get it fixed!
Unsure where I will place the tape as the problem is internal to the pump e.g the actual mating face to the hose pops in and out like turtles head in ya trousers.
