Hello all,
2010 le mans 2.7.
Can any one confirm if it's possible to enable the TPMS (ABS type) through VAG-Com and what the process is?
I keep getting flat tyres and I can't tell!
Printable View
Hello all,
2010 le mans 2.7.
No, it's not.
The C6 uses the system with the special valves and a whole load of sensors plotted around the car.
The A3 uses ABS pulses which is a nice freebie for me :approve:
but then if you are getting a lot of flat tyres you need to find out why and cure it.
oh, ok.
B8 but will give you some idea. - AudiEnthusiasts TPMS
Roy the B8 uses abs pulses whereas the A6 doesn't :)
I doubt they would be cross-compatible as its a totally different chassis layout.
Probably cost a fair few £££ anyway.
