Sudden power loss/hesitation
Hi guys,
I'm experiencing some quite worrying problems today.
Car:- 3.0tdi Quattro bmk
Starting from the beginning I had a service on Monday oil change using quantum platinum, air filter,I ran some engine flush, some archoil fuel treatment, and some archoil oil additive.
My fuel was just under half a tank and today it got low to the point of fuel light on and 15 miles left to empty I then topped up to full tank with v power.
Since Monday i had this intermittent problem when flooring it the car would have a sudden instant loss of power all dials on dash would go off for a split second - esp light flashed and brake warning would flash 3 times, mmi would go off and restart to the original radio station it was on when car was first started, then the usual cycle of dash lights would happen ... At the same time the car would drive normally instantly ....
Today however it got worse, a lot worse.
It started happening at lower speeds, or when hitting a large pot hole. Can be replicated too.
So I decided to change fuel filter and cleaned maf. Still happening and car's gear changes seem really hesitant - seems to drive quite rough too.
At one point the entire engine shut down with power steering loss too. Restarted car and it drove fine again albeit kind of rough.
I'll try get a video of the dash sequence when this happens when i get a chance.
I immediately done a vcds scan and will post the faults...however upon clearing them they haven't come back bar one...
Any ideas?
Fault codes are here:--
the only one that has come back after clearing is the alarm horn and the a/c sensor. although the glow plug one seems to be coming back after a few weeks of driving as does the intake manifold runner control
the map is a new one that i haven't seen before since owning this car.
I'm begging to think I've either knocked something near/around the air filter box when doing that or it's some ecu dying somewhere
Code:
Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02335 785 00200
VCID: 254BEF4DECFA271
6 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 001 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 249.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 8.89 V
Duty Cycle: 15.0 %
Temperature: 12.6°C
Bin. Bits: 00110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 001 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 249.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 8.89 V
Duty Cycle: 15.0 %
Temperature: 12.6°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 001 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 249.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 8.89 V
Duty Cycle: 15.0 %
Temperature: 12.6°C
Bin. Bits: 00110000
19591 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
RPM: 756 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Voltage: 13.53 V
Duty Cycle: 12.2 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
Temperature: 87.3°C
18061 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
RPM: 3465 /min
Torque: 62.4 Nm
Speed: 30.2 km/h
Duty Cycle: 35.9 %
Voltage: 13.68 V
Bin. Bits: 00101100
Torque: 405.6 Nm
Temperature: 94.5°C
16620 - Manifold Pressure / Boost Sensor (G31)
P0236 - 001 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 147 /min
Torque: 195.0 Nm
Speed: 13.4 km/h
Voltage: 2.040 V
Voltage: 11.70 V
Absolute Pres.: 979.2 mbar
Temperature: -17.1°C
Absolute Pres.: 1091.4 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004492
VCID: 2649E84191FC2C9
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 161754 km
Time Indication: 0
Date: 2013.06.20
Time: 14:31:00
Freeze Frame:
Hex Value: 0x2D80
Hex Value: 0x4006
Hex Value: 0x125E
Hex Value: 0x009F
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 B
Component: KLIMABETAETIGUNGH11 0100
Revision: 00000022 Serial number: 00000000036552
Coding: 0001046
VCID: DBBF09B51A3E211
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 95
Mileage: 160414 km
Time Indication: 0
Date: 2013.05.20
Time: 19:59:59
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
Component: KOMBIINSTR. M73 H08 0630
Revision: 00200000 Serial number: 4I1152L74
Coding: 0001443
Shop #: WSC 00000 000 00000
VCID: 1E39C0A1C9ACF49
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 161054 km
Time Indication: 0
Date: 2013.06.06
Time: 15:31:26
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 080080471801F6
Coding: 6CFE53C41B1104
VCID: 2757E54596F6351
1 Fault Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 161297 km
Time Indication: 0
Date: 2013.06.11
Time: 12:25:12
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000491320000
Coding: 0008435
Shop #: WSC 00137 211 56823
VCID: 2C5D1A698F10169
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0010
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 101
Mileage: 158953 km
Time Indication: 0
Date: 2013.03.21
Time: 12:10:49
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 141
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 00899 210 12701
VCID: DDBB07AD042A2F1
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 161752 km
Time Indication: 0
Date: 2013.06.20
Time: 14:31:02
Freeze Frame:
Voltage: 13.15 V
Count: 236
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H10 0080
Revision: 00000000 Serial number: 00000007515894
Coding: 0010900
VCID: 2143FB5DF8D2CB1
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 161638 km
Time Indication: 0
Date: 2013.06.17
Time: 17:45:23
Re: Sudden power loss/hesitation
So just mechanical changes recently and you're suffering from what seems to be multiple electrical problems?
Have you checked your battery connection and voltage from the alternator?
Erm what's the one that's come back...don't leave us in suspenders!
not checked battery connection or voltage yet. I'll do it with vcds until I can find my lost multimeter or buy a new one over the next few days...
Quote:
Originally Posted by
MarkTM
Just ordered my VCDS today, but even if I'd had it I'd test the battery/alternator and glow plug connectors first.
You can still do it as it's still light out!
techfreak
Hi guys,
Any ideas?
Sounds like a loose connection somewhere.
BTW. Audi state not to use fuel additives, oil aditives or engine flush.
When did you last drain / change your fuel filter ?
royclark
Yes I'm beginning to think loose connection.
Happened again twice on a short 3/4 mile journey soon as I hit a slight bump in the road - all power out and instantly back on.
I changed the fuel filter this evening after this started happening as a first point of call.
Why do Audi state that never to use those things? First I've heard of that and always used them inc on my last 4 vag group cars with no ill effect and positive results.
techfreak
I'm just reading up on that in my hand book.
No biodiesel. = damage to fuel system.
Do not mix fuel additives with the diesel.
Diesel must conform with EN590. Have a cetain number (CN) of at least 51.
No additives should be used with engine oil. Any damage caused by such additives will not be covered by warranty.
My bits added in bold
royclark
I'me just reading up on that in my hand book.
No biodiesel. = damage to fuel system. Same applies to all 'normal' diesels surely?
Do not mix fuel additives with the diesel. All Audi drivers best steer clear of Shell V-Power Nitro+ then!
Diesel must conform with EN590. Have a cetain number (CN) of at least 51. Applies to all consumer automotive diesel sold in the UE
Tech is your car in warranty or does it have FASH meaning if there's a failure you may be able to get Audi to contribute?
Have you had any signs of water inside the car? We are seeing more and more 4F's with the electronics boxes in the plenum chamber doubling up as goldfish bowls and it causes havoc and those fault codes point towards a wet ECU. Mind you you could just have the usual faulty manifold and need some new glow plugs.
Crasher does the water problem apply equally to saloons as estates?
Only asking as thought it was only Avants...don't know what Tech has though.
