Vag Com Fault Codes
What an excellent site this is. I have managed to solve a few probs on my motor over the past few months just from reading up on here. Thanks!
I have just done a scan on my 2001 GTTDI an these error codes are showing:
Address 46: Central Conv.
Controller: 1J0 959 799 AH
Component: 4V Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00445
2 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-10 - - - Intermittent
Address 56: Radio
Controller: 1J0 035 186 E
Component: Radio BNO 0005
Coding: 01403
Shop #: WSC 00028
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00853 - Loudspeaker(s): Rear
End --------------------------------------------------------------------------------------------------
I have had a search around and know the mirror fault probably just require the glass replacing so i will check that later on but i cant find any info on the radio fault. There is no obvious problem when using the radio apart from poor reception. Any ideas?
