I once saw on this site someone post a link to a site which allowed you to do a search on your car number plate and see a list of the spec it had when it left the factory..
Does anyone know where I can find this?
Printable View
just found it...
http://igorweb.org/equidec/Default.aspx
Does that site work? I entered my number plate and it said nothing.
I'm guessing it's not identity fraud stuff as I can't see what good a registration number would do without documentation to back it up.
-AS
You dont enter your number plate, (title is slightly decieving). If you look in the front of your service book which came with the car you should see a printout with several 3 digit codes, if you enter these codes followed by a semi colon with no spaces it will explain exactly what was fitted to your car in the factory.
Hope this helps
Doors, wheels, brakes, headlights......
;P
something like that:D
Glass's Guide can do this.
If you go to http://www.glass.co.uk you can do a check for the value of a car from the number plate. Follow the "Used Car Prices" link on the front page. They charge you for the valuation, but before you get to that stage there's a section that gives the exact model of the car. There's a tab there which lists original equipment.
I'm starting to look for a 2004 model year A4 avant 1.9 TDi (6) 130 so I can get cruise control, heated mirrors and rear electric windows. The site is proving very useful :-)
