A6 Avant 2006 model - change left side rear indicator bulb
How do you loosen the light fitting so i can get to the bulb, i cannot find the black screw that is mentioned in the manual, it is on the drivers rear side but not on the left side.
Do you undo something else
Re: A6 Avant 2006 model - change left side rear indicator bulb
I assume there's a cover blanking off a hole in the inside trim that you'd have to remove to reveal the fixing?
open the panel on the left hand side when you open the boot and you will see the screw cover
just went out and looked :)
1 Attachment(s)
thanks, i have added an image of the inside. i have changed the bulbs on the drivers side rear, that was easy, black screw fitting came out and slide light casing, not sure on the passenger side which nut to undo.
thanks i have added an image of the inside. i have changed the bulbs on the drivers side rear, that was easy, black screw fitting came out and slide light casing, not sure on the passenger side which nut to undo.
Quote:
Originally Posted by
Chris Leafe
It is the same style of plastic nut on both sides in a recess...
just done a search Removing avant rear lamp unit
pictures halfway down the first page
A6_Chris
LOL! Chris :) ... was debating about linking that thread :) ... I thought I'd nip out and do updated photos of for both sides...
