Audi A2 Tdi 2001 Fault Codes HELP!!!
Hello there,
Could anybody shed a bit of light on what these fault codes mean:
18062 - 163
KWP1281
Please check DTC
Memory of instrument
Cluster : P1654
17948 - 163
KWP1281
Signal: Signal too
High : P1540
00812 - 163
KWP12081
Brake Pressure Release Solenoid
(F84)
Static - No define
I have noticed the coolanr temp gauge will only reach 80 degrees when engine have been ran.
I also understand that the abs light comes on when driving through standing water.
Any ideas would be very much appreciated,
Buzz
Re: Audi A2 Tdi 2001 Fault Codes HELP!!!
What are you using to read the codes? you can look up codes and possible solutions here Ross-Tech Wiki
I'm using an AUTEL VAG code reader.
